メインコンテンツにスキップ
Axess TA2513-10WT Side Button Replacement
必要な工具と部品
  1. Axess TA2513-10WT Side Button Replacement, Back Cover: 手順 1、 1の画像 1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Side Button Replacement: 手順 2、 3の画像 1 Axess TA2513-10WT Side Button Replacement: 手順 2、 3の画像 2 Axess TA2513-10WT Side Button Replacement: 手順 2、 3の画像 3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Side Button Replacement: 手順 3、 1の画像 1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Side Button Replacement: 手順 4、 1の画像 1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Side Button Replacement, Buttons: 手順 5、 2の画像 1 Axess TA2513-10WT Side Button Replacement, Buttons: 手順 5、 2の画像 2
    • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
  6. Axess TA2513-10WT Side Button Replacement: 手順 6、 2の画像 1 Axess TA2513-10WT Side Button Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    購入する
    • Unlatch the clear rubber holder from the posts with the tweezers.
  7. Axess TA2513-10WT Side Button Replacement: 手順 7、 2の画像 1 Axess TA2513-10WT Side Button Replacement: 手順 7、 2の画像 2
    • With tweezers, pull the rubber holder from the back cover completely.
  8. Axess TA2513-10WT Side Button Replacement: 手順 8、 3の画像 1 Axess TA2513-10WT Side Button Replacement: 手順 8、 3の画像 2 Axess TA2513-10WT Side Button Replacement: 手順 8、 3の画像 3
    • Remove the individual buttons with tweezers.
終わりに
作成者
10人の作成者と共同で作成されました。
Lori Scott
メンバー登録日: 03/24/15
101 ポイント
1ガイドが承認済み
チーム
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015人のメンバー
BU-SHAVER-S15S6G3
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 231
