メインコンテンツにスキップ
Axess TA2513-10WT Battery Replacement
必要な工具と部品
  1. Axess TA2513-10WT Battery Replacement, Back Cover: 手順 1、 1の画像 1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Battery Replacement: 手順 2、 3の画像 1 Axess TA2513-10WT Battery Replacement: 手順 2、 3の画像 2 Axess TA2513-10WT Battery Replacement: 手順 2、 3の画像 3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Battery Replacement: 手順 3、 1の画像 1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Battery Replacement: 手順 4、 1の画像 1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Battery Replacement, Battery: 手順 5、 1の画像 1
    • Shove the Spudger below the battery pack to remove any tape or adhesive residue.
  6. Axess TA2513-10WT Battery Replacement: 手順 6、 1の画像 1
    • Lift the battery up with your hands to ensure complete detachment from the screen.
  7. Axess TA2513-10WT Battery Replacement: 手順 7、 1の画像 1
    • Identify the red wire attached to the node labeled "B+" and the black wire attached to the node labeled "B-"
  8. Axess TA2513-10WT Battery Replacement: 手順 8、 1の画像 1
    • Press the heated soldering iron down on the "B+" node while simultaneously tugging on the red wire.
  9. Axess TA2513-10WT Battery Replacement: 手順 9、 1の画像 1
    • Remove the red wire from the node labeled "B+"
  10. Axess TA2513-10WT Battery Replacement: 手順 10、 1の画像 1
    • Using the same process as the red wire, detach the black wire from the node labeled "B-".
  11. Axess TA2513-10WT Battery Replacement: 手順 11、 1の画像 1
    • The battery should now be separated from both the screen and circuit board
終わりに
作成者
2人の作成者と共同で作成されました。
Steven Kavanagh
メンバー登録日: 03/24/15
301 ポイント
3のガイドは作成済み
チーム
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015人のメンバー
BU-SHAVER-S15S6G3
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 296
