はじめに
Use this guide to replace a malfunctioning OLED Board in your Axe Empire 2.0 Marker.
The OLED Board is a screen on a paintball marker that allows you to see text and graphics of your devices settings. A malfunctioning OLED Board can cause your marker to make you unable to modify your devices setting, view important information, or unable to turn the device on at all.
A battery leaking battery acid is unsafe so I recommend you wear gloves when getting in the inside of your Axe Empire 2.0.
In step 1 of this guide, you will need to use an old toothbrush and possibly a rag. Since this device is used with players with other people and constantly getting hit with paint, cleaning out the Allen heads will ensure the correct Allen keys will fit.
必要な工具と部品
