メインコンテンツにスキップ
Autosampler Battery Replacement & Voltage Check (For Old & New Versions)
必要な工具と部品
  1. Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Disconnect the batteries completely: 手順 1、 3の画像 1 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Disconnect the batteries completely: 手順 1、 3の画像 2 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Disconnect the batteries completely: 手順 1、 3の画像 3
    • 1. Disconnect the plug to the solar panel (yellow circle).
    • Then, grabbing the green connector and pull the battery connector from the solar charge controller (blue arrow).
    • This will be done inside the node. It was removed from the node to make it easier to see for the tutorial.
    • 2. Disconnect the plugs for the autosampler battery.
    • 3. Disconnect the connector that plugs into the battery port of the sampler.
    • If disconnect battery before solar panel, this can damage the solar charger!
  2. Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Checking battery voltages: 手順 2、 3の画像 1 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Checking battery voltages: 手順 2、 3の画像 2 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Checking battery voltages: 手順 2、 3の画像 3
    • 4. Make sure multimeter is measuring in DC current (red boxes).
    • Make sure multimeter is measuring in Volts (blue box).
    • 5. Check the voltage of the lead acid autosampler battery. Fully charged lead acid battery should be around 13-14 V.
    • Remember: Red to red and black to black!
    • 6. Check the voltage of the lithium ion node battery. Fully charged lithium ion battery should around 4 V.
  3. Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Reconnect the batteries: 手順 3、 3の画像 1 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Reconnect the batteries: 手順 3、 3の画像 2 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Reconnect the batteries: 手順 3、 3の画像 3
    • 7. First reconnect the autosampler battery (black box).
    • 8. Then reconnect lithium ion battery in the node (blue box).
    • Remember to plug in the other connector into the autosampler.
    • 9. Secure solar charge controller to the side of the enclosure using velcro (red box).
    • Then plug in the solar panel last (orange box).
ゴール
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Brooke Mason
メンバー登録日: 05/29/19
2,928 ポイント
17のガイドは作成済み
チーム
Open-Storm Open-Storm人のメンバー
Community
14 メンバー
24のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 171
