メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Automatic Tommy 20 Trigger Spring Replacement
必要な工具と部品
    1. Automatic Tommy 20 Trigger Spring Replacement, Splitting the Gun into Two Halves: 手順 1、 2の画像 1 Automatic Tommy 20 Trigger Spring Replacement, Splitting the Gun into Two Halves: 手順 1、 2の画像 2
      • Locate the orange slider on the front side of the gun.
      • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
      FixBotに聞いてみる
      コメントを追加
    2. Automatic Tommy 20 Trigger Spring Replacement: 手順 2、 3の画像 1 Automatic Tommy 20 Trigger Spring Replacement: 手順 2、 3の画像 2 Automatic Tommy 20 Trigger Spring Replacement: 手順 2、 3の画像 3
      • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
      • Remove all parts within the chamber to be able to completely detach the nose of the gun.
      • Be careful to keep track of all the components for reassembly.
      FixBotに聞いてみる
      コメントを追加
    1. Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: 手順 3、 3の画像 1 Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: 手順 3、 3の画像 2 Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: 手順 3、 3の画像 3
      • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
      • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
      FixBotに聞いてみる
      コメントを追加
    2. Automatic Tommy 20 Trigger Spring Replacement: 手順 4、 1の画像 1
      • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
      FixBotに聞いてみる
      コメントを追加
    1. Automatic Tommy 20 Trigger Spring Replacement, Split the Gun into Two Halves: 手順 5、 2の画像 1 Automatic Tommy 20 Trigger Spring Replacement, Split the Gun into Two Halves: 手順 5、 2の画像 2
      • Grab both sides of the gun and pull forcefully in an upward and outward motion to remove from the light green stock.
      • If this is your first time disassembling your gun, the stock will be glued to each half of the gun's body. To break off the stock from the frame of the gun, you will need to careful wiggle the two halves so that the glue will break apart. The plastic on the gun may break or warp slightly.
      FixBotに聞いてみる
      コメントを追加
    2. Automatic Tommy 20 Trigger Spring Replacement, Removing the Battery Box: 手順 6、 2の画像 1 Automatic Tommy 20 Trigger Spring Replacement, Removing the Battery Box: 手順 6、 2の画像 2
      • Remove the two 1/16 in. screws attaching the battery box to the frame of the gun using a Phillips #00 Screwdriver.
      • Lift the battery box off the frame of the gun to give yourself access to the trigger mechanism.
      FixBotに聞いてみる
      コメントを追加
    3. Automatic Tommy 20 Trigger Spring Replacement, Removing the Screws from the Trigger Mechanism: 手順 7、 1の画像 1
      • Remove the two 1/6 in. screws connecting the trigger and trigger spring to the frame of the gun using a Phillips #00 Screwdriver.
      FixBotに聞いてみる
      コメントを追加
    4. Automatic Tommy 20 Trigger Spring Replacement: 手順 8、 2の画像 1 Automatic Tommy 20 Trigger Spring Replacement: 手順 8、 2の画像 2
      • Lift the plastic trigger away from the gun along with the attached spring.
      • Make sure you do not lift the trigger without the spring or the spring may stretch and no longer function properly.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Moira Foster
メンバー登録日: 10/09/14
419 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 6-22, Maness Fall 2014 Cal Poly, Team 6-22, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S6G22
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 44
今までの合計 1,281
