メインコンテンツにスキップ
Automatic Tommy 20 Dart Accelerator Replacement
必要な工具と部品
  1. Automatic Tommy 20 Dart Accelerator Replacement, Splitting the Gun into Two Halves: 手順 1、 2の画像 1 Automatic Tommy 20 Dart Accelerator Replacement, Splitting the Gun into Two Halves: 手順 1、 2の画像 2
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Dart Accelerator Replacement: 手順 2、 3の画像 1 Automatic Tommy 20 Dart Accelerator Replacement: 手順 2、 3の画像 2 Automatic Tommy 20 Dart Accelerator Replacement: 手順 2、 3の画像 3
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Dart Accelerator Replacement, Disassembling the Nose of the Gun: 手順 3、 3の画像 1 Automatic Tommy 20 Dart Accelerator Replacement, Disassembling the Nose of the Gun: 手順 3、 3の画像 2 Automatic Tommy 20 Dart Accelerator Replacement, Disassembling the Nose of the Gun: 手順 3、 3の画像 3
    • Remove all five 1/16 in. screws holding the nose of the gun together using a Phillips #00 screwdriver.
    • Look out for the hidden fifth screw behind the thin light green tape near the bushing itself. Peel the tape using your finger to gain access.
  4. Automatic Tommy 20 Dart Accelerator Replacement, Removing the Bushing: 手順 4、 1の画像 1
    • Pick up the now split half of the nose of the gun that does not still have the orange tip attached to it.
    • Remove the bushing by simply pulling it away from the plastic.
  5. Automatic Tommy 20 Dart Accelerator Replacement, Dart Accelerator: 手順 5、 2の画像 1 Automatic Tommy 20 Dart Accelerator Replacement, Dart Accelerator: 手順 5、 2の画像 2
    • Unscrew the two screws holding the accelerator in place with a Phillips #00 screwdriver
  6. Automatic Tommy 20 Dart Accelerator Replacement, Removing the Accelerator: 手順 6、 1の画像 1
    • Pull back on the accelerator away from the plastic to remove from frame.
    • Be careful to not pull too quickly or too hard to avoid damaging the wiring.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Reed Garmsen
メンバー登録日: 10/07/14
468 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-22, Maness Fall 2014 Cal Poly, Team 6-22, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S6G22
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,188
