メインコンテンツにスキップ
August Smart Lock Gear Replacement
必要な工具と部品
  1. August Smart Lock Gear Replacement, Gear: 手順 1、 3の画像 1 August Smart Lock Gear Replacement, Gear: 手順 1、 3の画像 2 August Smart Lock Gear Replacement, Gear: 手順 1、 3の画像 3
    • Flip the device over so the metal plate is facing you.
    • Undo the latches on the side to remove the metal plate.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
  2. August Smart Lock Gear Replacement: 手順 2、 3の画像 1 August Smart Lock Gear Replacement: 手順 2、 3の画像 2 August Smart Lock Gear Replacement: 手順 2、 3の画像 3
    • Lift the cover off the device and set to the side.
    • The cover contains the speaker which is connected to the motherboard so do not pull to far apart.
    • Remove the gears as shown.
終わりに
12 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
William Fink
メンバー登録日: 09/26/17
814 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S11-G6, Passmore Fall 2017 USF Tampa, Team S11-G6, Passmore Fall 2017人のメンバー
USFT-PASSMORE-F17S11G6
4 メンバー
3のガイドは作成済み
8件のガイドコメント
The tittle of this topic is: August Smart Lock Gear Replacement, but I don't see any spare part replacement at all!
Walter Quintero - 返信
Any tips on where to get replacement gears?
Byron H - 返信
The gear connecting the motor is cracked. I'd also like to know where to get parts other than buying another broken August lock that's broken in another way.
Robert F. Jobin Jr. - 返信
Robert, where you able to find this replacement gear? Mine broke this week and having a hard time to find the part. Thanks
Luiz Cavalcante -
Anyone find gear replacements? The. Am on the motor shaft cracked on mine
pennytrotz - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 51
今までの合計 13,534
