この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The purpose of this guide is to show you how to open up your Audiovox. Once inside, you will be able to check out all of the different internal components, and, if needed, begin repair!
必要な工具と部品
Begin by applying constant pressure to the base of your Audiovox while holding the plastic casing. Do this until the plastic casing is completely removed.
もう少しです!
終わりに
