メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
The purpose of this guide is to show you how to open up your Audiovox. Once inside, you will be able to check out all of the different internal components, and, if needed, begin repair!
パーツ
パーツは指定されていません。
  1. Before opening your Audiovox, be sure to turn it upside down.
    • Before opening your Audiovox, be sure to turn it upside down.
    • Begin by applying constant pressure to the base of your Audiovox while holding the plastic casing. Do this until the plastic casing is completely removed.
  2. Insert a Phillips #1 screwdriver into the hole at the corner of the base and remove the screw.
    • Insert a Phillips #1 screwdriver into the hole at the corner of the base and remove the screw.
    • Repeat this step for the remaining other three screws.
  3. Make sure to orient the Audiovox right side up.
    • Make sure to orient the Audiovox right side up.
    • Gently pull off the top panel of the Audiovox, as shown in the picture, to ensure that the panel detaches properly.
  4. Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Gently, as to not disconnect any of the attached wires, pull back the board to view the soldered connections (on the other side) as well as the internal components.
    • Gently, as to not disconnect any of the attached wires, pull back the board to view the soldered connections (on the other side) as well as the internal components.
終わりに
Savannah Smith
メンバー登録日: 2013年04月18日
51 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 10-39, Amido Spring 2013 Cal Poly, Team 10-39, Amido Spring 2013人のメンバー
CPSU-AMIDO-S13S10G39
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 234
