この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If the backlight isn't working, install a new one! This guide shows you how to change out the old backlight that may not be working right.
Note: This guide involves soldering and should not be done by children. If you do not know how to solder, check out はんだ付けとはんだ除去の作業ガイド to learn how before beginning this guide.
必要な工具と部品
Turn the device upside down.
Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
Insert a Phillips #1 screwdriver into the corner, square, holes and push the backlight board up away from the plastic casing.
