はじめに
Here is how you replace the logic board from the cell phone.
Hold the phone in one hand, slide latch, and pull to remove the battery. Hold the phone in one hand, slide latch, and pull to remove the battery.
  • Hold the phone in one hand, slide latch, and pull to remove the battery.
コメントを追加する
Grasp antenna at its base and unscrew. Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly. Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
  • Grasp antenna at its base and unscrew.
  • Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
コメントを追加する
Remove small rubber insert from top of phone to access the top screw. Warning: Screws are very small and may be difficult to see while unscrewing. Unscrew all five (5) screws on the back of cell phone.
  • Remove small rubber insert from top of phone to access the top screw.
  • Warning: Screws are very small and may be difficult to see while unscrewing.
  • Unscrew all five (5) screws on the back of cell phone.
  • If screws do not remove after fully unthreading, gently invert and tap phone in hand until the screws come loose.
コメントを追加する
Wedge back plate away from cell phone using the leverage from the plastic spudger. The volume control button on the left side of the phone will be loose. Make sure to carefully reinsert during reassembly. Detach logic board from LCD screen connector by gently detaching the small copper plate on the top right of the logic board. (shown circled in blue and detached)
  • Wedge back plate away from cell phone using the leverage from the plastic spudger.
  • The volume control button on the left side of the phone will be loose. Make sure to carefully reinsert during reassembly.
  • Detach logic board from LCD screen connector by gently detaching the small copper plate on the top right of the logic board. (shown circled in blue and detached)
コメントを追加する
Pop the logic board out from the front of the cell phone. Before reassembly, be sure keypad is lined up with logic board. Before reassembly, be sure camera lens is properly aligned at the top of the logic board and volume controls are in place.
  • Pop the logic board out from the front of the cell phone.
  • Before reassembly, be sure keypad is lined up with logic board.
  • Before reassembly, be sure camera lens is properly aligned at the top of the logic board and volume controls are in place.
コメントを追加する
Grasp camera.
  • Grasp camera.
  • Slide camera out of slot from logic board.
  • Camera is difficult to reassemble; there is a white clip for easy camera replacement. Verify that you orient the camera correctly when reinserting.
コメントを追加する
  • Attach camera to new logic board.
  • Follow steps in reverse order to replace logic board.
コメントを追加する
まとめ
Aaron Shaw
メンバー登録日: 2010年04月15日
150 ポイント
14のガイドは作成済み
チーム
Cal Poly, Team 28-31, Regan Spring 2010 Cal Poly, Team 28-31, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S28G31
4 メンバー
14のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,573
