メインコンテンツにスキップ
はじめに
Here is how you remove the antenna of the cell phone.
  1. Hold the phone in one hand, slide the latch up, and pull the battery up to remove it. Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
    • Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
  2. Grasp the antenna at its base and twist to unscrew. Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly. Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
    • Grasp the antenna at its base and twist to unscrew.
    • Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
終わりに
2 の人々がこのガイドを完成させました。
Aaron Shaw
メンバー登録日: 2010年04月15日
150 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 28-31, Regan Spring 2010 Cal Poly, Team 28-31, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S28G31
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,002
