はじめに
This guide will deal with how to replace the broken or missing belt drive for Audio-Technica AT-LP60BK-BT Bluetooth Wireless Turntable. The rubber band could cause a malfunction and break after using a long time or under extreme temperatures.
Before using this guide, make sure the size of the new belt is designed specifically for this model to avoid motor overheat problem.
必要な工具と部品
ある他の人がこのガイドを完成しました。
