メインコンテンツにスキップ
Atari 5200 number pad cleaning or replacement
必要な工具と部品
  1. Atari 5200 number pad cleaning or replacement, Open the controller: 手順 1、 3の画像 1 Atari 5200 number pad cleaning or replacement, Open the controller: 手順 1、 3の画像 2 Atari 5200 number pad cleaning or replacement, Open the controller: 手順 1、 3の画像 3
    • Turn the controller over, exposing the three screws on the back (marked by the orange circles). Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    • Try not to move the joystick when reassembling. This will almost assuredly break your alignment. The less the joystick is moved, the easier it will be to realign the joystick to the pots.
  2. Atari 5200 number pad cleaning or replacement, Cleaning/Reseating (number pad front and back): 手順 2、 3の画像 1 Atari 5200 number pad cleaning or replacement, Cleaning/Reseating (number pad front and back): 手順 2、 3の画像 2 Atari 5200 number pad cleaning or replacement, Cleaning/Reseating (number pad front and back): 手順 2、 3の画像 3
    • Take out the rubber button module of the number pad.
    • With access to the number pad sensors, use compressed air to blow out dust.
    • Wipe the sensors clean with a cloth dabbed with alcohol.
  3. Atari 5200 number pad cleaning or replacement, Reassembly Part 1: 手順 3、 2の画像 1 Atari 5200 number pad cleaning or replacement, Reassembly Part 1: 手順 3、 2の画像 2
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  4. Atari 5200 number pad cleaning or replacement, Reassembly Part 2: 手順 4、 2の画像 1 Atari 5200 number pad cleaning or replacement, Reassembly Part 2: 手順 4、 2の画像 2
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
  5. Atari 5200 number pad cleaning or replacement, Reassembly Part 3: 手順 5、 3の画像 1 Atari 5200 number pad cleaning or replacement, Reassembly Part 3: 手順 5、 3の画像 2 Atari 5200 number pad cleaning or replacement, Reassembly Part 3: 手順 5、 3の画像 3
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Alan Abelson
メンバー登録日: 09/26/14
233 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014人のメンバー
USFT-STAGGERS-F14S13G1
5 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 23
今までの合計 538
