メインコンテンツにスキップ
Atari 5200 Controller Flex Board Replacement
必要な工具と部品
  1. Atari 5200 Controller Flex Board Replacement, Opening up the controller: 手順 1、 3の画像 1 Atari 5200 Controller Flex Board Replacement, Opening up the controller: 手順 1、 3の画像 2 Atari 5200 Controller Flex Board Replacement, Opening up the controller: 手順 1、 3の画像 3
    • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    • Try not to move the joystick when reassembling. This will almost assuredly break your alignment. The less the joystick is moved, the easier it will be to realign the joystick to the pots.
  2. Atari 5200 Controller Flex Board Replacement, Removing the Circuit Board: 手順 2、 3の画像 1 Atari 5200 Controller Flex Board Replacement, Removing the Circuit Board: 手順 2、 3の画像 2 Atari 5200 Controller Flex Board Replacement, Removing the Circuit Board: 手順 2、 3の画像 3
    • Slide out the strip of the board connected to the controller's START, PAUSE, and RESET buttons.
  3. Atari 5200 Controller Flex Board Replacement: 手順 3、 3の画像 1 Atari 5200 Controller Flex Board Replacement: 手順 3、 3の画像 2 Atari 5200 Controller Flex Board Replacement: 手順 3、 3の画像 3
    • Peel off the old circuit board.
    • The buttons should fall out/be removable.
    • Disconnect it from the wire connector.
  4. Atari 5200 Controller Flex Board Replacement, Adding the new board: 手順 4、 3の画像 1 Atari 5200 Controller Flex Board Replacement, Adding the new board: 手順 4、 3の画像 2 Atari 5200 Controller Flex Board Replacement, Adding the new board: 手順 4、 3の画像 3
    • Place the new circuit board where the old one was.
    • Glue/tape it in places where the previous board was held.
    • Connect it to the wire connector.
  5. Atari 5200 Controller Flex Board Replacement, Reassembly Part 1: 手順 5、 2の画像 1 Atari 5200 Controller Flex Board Replacement, Reassembly Part 1: 手順 5、 2の画像 2
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  6. Atari 5200 Controller Flex Board Replacement, Reassembly Part 2: 手順 6、 2の画像 1 Atari 5200 Controller Flex Board Replacement, Reassembly Part 2: 手順 6、 2の画像 2
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
  7. Atari 5200 Controller Flex Board Replacement: 手順 7、 3の画像 1 Atari 5200 Controller Flex Board Replacement: 手順 7、 3の画像 2 Atari 5200 Controller Flex Board Replacement: 手順 7、 3の画像 3
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the Screws
ゴール
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Zach Petryszyn
メンバー登録日: 09/26/14
21 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014人のメンバー
USFT-STAGGERS-F14S13G1
5 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 29
今までの合計 2,971
