はじめに
Tools needed include an iFixit opening tool, a metal spudger, a removable head screwdriver with a T3 bit and a PH0 bit, and needle-nosed tweezers.
必要な工具と部品
Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
Gently move the tool around the edges towards each corner until the back is removed.
2 件のコメント
You can read T3 in the summary and T4 in the instructions: which one do I need?
Does this fix the Zenfone 4 max camera black screen?
this is not right..
Filipe Silva - 返信
