メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
If your Asus Zenfone 4 Max phone fails to charge, it could be due to a malfunctioning battery. This guide will help you remove your phone battery and replace it with a new one. Replacing the battery must be done with great care.
パーツ
パーツは指定されていません。
  1. Using a removable head screwdriver and a T3 bit, begin by removing the two screws located on either side of the charging port. Using a removable head screwdriver and a T3 bit, begin by removing the two screws located on either side of the charging port.
    • Using a removable head screwdriver and a T3 bit, begin by removing the two screws located on either side of the charging port.
  2. Gently wedge the opening tool between the phone and the back casing.
    • Gently wedge the opening tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  3. 電源プラグから解放されて、好きな場所で勉強する。
    Mac用バッテリー修正キット
    修理キットを探す
    Mac用バッテリー修正キット
    修理キットを探す
  4. Once the back has been removed, you will need to unscrew the four screws on the bottom panel with an AT3 bit. Once the back has been removed, you will need to unscrew the four screws on the bottom panel with an AT3 bit. Once the back has been removed, you will need to unscrew the four screws on the bottom panel with an AT3 bit.
    • Once the back has been removed, you will need to unscrew the four screws on the bottom panel with an AT3 bit.
  5. Remove the bottom panel.
    • Remove the bottom panel.
  6. Wedge an opening tool between the battery and phone. Gently pry the battery out of the device.
    • Wedge an opening tool between the battery and phone.
    • Gently pry the battery out of the device.
    • You can move the opening on either side of the battery as well as the bottom to aid in removal.
  7. Remove the battery and replace it with the new battery.
    • Remove the battery and replace it with the new battery.
終わりに
2 の人々がこのガイドを完成させました。
Maegan West
メンバー登録日: 2018年10月02日
724 ポイント
4のガイドは作成済み
チーム
Sam Houston State, Team S11-G6, Blackburne Fall 2018 Sam Houston State, Team S11-G6, Blackburne Fall 2018人のメンバー
SHSU-BLACKBURNE-F18S11G6
4 メンバー
5のガイドは作成済み
コメント1件
My FPC connector is broken as well as female battery connector, are these worth the time and money to replace or are new motherboards available?
Off topic: But anyone have success removing glass without damaging digitizer without any specialized tools on a xooid I have two 4max pro i have a new glass only:/uv glue / two back case, home buttons,2 replacement earpiece speakers, two sim trays, one rose gold and white one black on black, both useless now. Any advice of sourcing parts, or try to seperate glass, desolder and replace battery connectors or just scrap it all?
joemarvcontractor - 返信
コメントを追加
統計データを表示:
過去 24時間: 10
過去 7 日: 62
過去 30 日: 271
今までの合計 5,595
