メインコンテンツにスキップ
はじめに
This guide will demonstrate how to replace the battery of a Zenfone 3. This may be necessary if the battery has been damaged, will not hold a charge, or drains excessively quickly. For this guide, you will need the tweezers, Torx T2 screwdriver, a prying tool, and the Phillips #00 screwdriver.
  1. Using a pair of tweezers, pull put the SIM card tray and set it to the side. Using a pair of tweezers, pull put the SIM card tray and set it to the side.
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. Remove the two 2 mm screws using a Torx T2 screwdriver.
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone. There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. Peel back the silver tape.
    • Peel back the silver tape.
  6. Disconnect the battery connections.
    • Disconnect the battery connections.
  7. Pry and remove the battery.
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
終わりに
4 の人々がこのガイドを完成させました。
Joshua Fontenelle
メンバー登録日: 2018年09月10日
223 ポイント
1ガイドが承認済み
チーム
University of Alabama, Team S2-G7, Bedsole Fall 2018 University of Alabama, Team S2-G7, Bedsole Fall 2018人のメンバー
UA-BEDSOLE-F18S2G7
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 64
今までの合計 2,616
