メインコンテンツにスキップ
Asus Zenbook UX31E LCD Screen Replacement
必要な工具と部品
  1. Asus Zenbook UX31E LCD Screen Replacement, Back Cover: 手順 1、 1の画像 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E LCD Screen Replacement: 手順 2、 1の画像 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E LCD Screen Replacement, Battery: 手順 3、 2の画像 1 Asus Zenbook UX31E LCD Screen Replacement, Battery: 手順 3、 2の画像 2
    • Disconnect the battery from the motherboard by gently pulling up and down on the connector.
  4. Asus Zenbook UX31E LCD Screen Replacement: 手順 4、 2の画像 1 Asus Zenbook UX31E LCD Screen Replacement: 手順 4、 2の画像 2
    • Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
  5. Asus Zenbook UX31E LCD Screen Replacement: 手順 5、 2の画像 1 Asus Zenbook UX31E LCD Screen Replacement: 手順 5、 2の画像 2
    • Remove the battery. (Picture-1)
    • Picture of what the battery looks like.(Picture-2)
  6. Asus Zenbook UX31E LCD Screen Replacement, Speaker: 手順 6、 1の画像 1
    • Use the plastic opening tool to pry open the back cover of the laptop.
    • Remove the bottom panel of the laptop.
  7. Asus Zenbook UX31E LCD Screen Replacement: 手順 7、 2の画像 1 Asus Zenbook UX31E LCD Screen Replacement: 手順 7、 2の画像 2
    • Remove the screw connecting the speaker component to the motherboard using the screwdriver.
  8. Asus Zenbook UX31E LCD Screen Replacement: 手順 8、 2の画像 1 Asus Zenbook UX31E LCD Screen Replacement: 手順 8、 2の画像 2
    • Disconnect the sound cable from the motherboard.
  9. Asus Zenbook UX31E LCD Screen Replacement: 手順 9、 2の画像 1 Asus Zenbook UX31E LCD Screen Replacement: 手順 9、 2の画像 2
    • Using the plastic opening tool, pry open the speaker component from the computer.
  10. Asus Zenbook UX31E LCD Screen Replacement, SSD: 手順 10、 1の画像 1
    • Attach your Anti-Static Wrist Wrap to something metal as to not shock your system.
    • Peel back the warranty sticker to reveal the screw under it.
    • Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
  11. Asus Zenbook UX31E LCD Screen Replacement: 手順 11、 2の画像 1 Asus Zenbook UX31E LCD Screen Replacement: 手順 11、 2の画像 2
    • Using your hand, pull the SSD out from its slot.
  12. Asus Zenbook UX31E LCD Screen Replacement, Fan: 手順 12、 2の画像 1 Asus Zenbook UX31E LCD Screen Replacement, Fan: 手順 12、 2の画像 2
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  13. Asus Zenbook UX31E LCD Screen Replacement: 手順 13、 1の画像 1
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  14. Asus Zenbook UX31E LCD Screen Replacement: 手順 14、 2の画像 1 Asus Zenbook UX31E LCD Screen Replacement: 手順 14、 2の画像 2
    • Unscrew the two screws that are across each other.
  15. Asus Zenbook UX31E LCD Screen Replacement: 手順 15、 2の画像 1 Asus Zenbook UX31E LCD Screen Replacement: 手順 15、 2の画像 2
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
  16. Asus Zenbook UX31E LCD Screen Replacement, LCD Screen: 手順 16、 1の画像 1
    • Although replacement guides are listed as prerequisites, they are mainly used for disassembly.
    • At the marked locations, unscrew 7 screws with your Phillips 00 Precision Screwdriver.
    • At the marked locations (under certain components), unscrew 3 screws with your Phillips 00 Precision Screwdriver.
  17. Asus Zenbook UX31E LCD Screen Replacement: 手順 17、 1の画像 1
    • Carefully pull out the ribbon connecting your keyboard and motherboard from the motherboard.
    • This is a very delicate component, so do handle it with care.
  18. Asus Zenbook UX31E LCD Screen Replacement: 手順 18、 1の画像 1
    • At the bottom right corner of your laptop, carefully pull the connector from its socket.
  19. Asus Zenbook UX31E LCD Screen Replacement: 手順 19、 2の画像 1 Asus Zenbook UX31E LCD Screen Replacement: 手順 19、 2の画像 2
    • Carefully pull the black wire with a copper connector out from its socket.
    • Carefully pull the white wire with a copper connector out from its socket.
    • When reassembling, you will hear a pop when connecting these back.
  20. Asus Zenbook UX31E LCD Screen Replacement: 手順 20、 1の画像 1
    • Carefully unplug this white wire from the motherboard
  21. Asus Zenbook UX31E LCD Screen Replacement: 手順 21、 1の画像 1
    • At the corners between your screen and the rest of your laptop, unscrew 4 screws with your Phillips 00 Precision Screwdrivers.
  22. Asus Zenbook UX31E LCD Screen Replacement: 手順 22、 1の画像 1
    • Slide the display to either the left or right to loosen it.
    • Pull the display away from the rest of your laptop.
終わりに
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Charles Jackson
メンバー登録日: 02/02/17
668 ポイント
3のガイドは作成済み
チーム
UW Tacoma, Team 1-2, Rose Winter 2017 UW Tacoma, Team 1-2, Rose Winter 2017人のメンバー
UWT-ROSE-W17S1G2
4 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 29
今までの合計 8,717
