はじめに
This guide demonstrates how to replace the battery of your Asus Zenbook UX31A. This may be necessary if the battery no longer holds a charge, or the laptop will not charge at all.
The battery is responsible for providing power to all the components of your computer. If your battery has issues, it may lead to your computer no longer powering on.
Before following this guide, make sure that there is nothing wrong with your charging cable and that your charging port is clear of debris as this might lead to the computer appearing as if it has battery issues. Try other charging cables for your computer, and try cleaning out your charging port with an ESD safe brush.
Before you proceed, make sure to power the computer all the way down and disconnect the charging cable.
必要な工具と部品
Use a T6 screwdriver to remove the ten 6 mm case screws.
The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
Remove the back cover from the laptop.
ある他の人がこのガイドを完成しました。
