はじめに
This guide is to replace the speakers on an Asus Xenbook UX303L Laptop should they stop functioning correctly. During replacement be careful not to pull on the wires too hard as well as be sure you have discharged any static electricity to prevent any static charge from damaging laptop components.
必要な工具と部品
Remove the eight 3mm screws using the T5 Torx Screwdriver.
Remove the 8mm screw using the T5 Torx Screwdriver.
終わりに
ある他の人がこのガイドを完成しました。
