このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Peel off the silver tape that is to the right of the audio jack about halfway, so it is off of the silver plate.
Use the tweezers to disconnect the press fit connector underneath the tape, right above the silver plate.
Gently lift up until the camera and the connector is removed.
この手順は未翻訳です。 翻訳を手伝う。
Right above the battery socket, pop up the press fit connector at the end of the orange ribbon cable on the right.
Pry up the tab of the ZIF connector on the left to disengage the locking connector.
Gently pull out the ribbon cable going into the opening created by lifting the tab.
この手順は未翻訳です。 翻訳を手伝う。
Pull the tab that is located to the left of the camera button, adjacent to the volume up button.
Pull out the gold headed coaxial cable on the bottom right of the motherboard.
Use the screwdriver to take out the one Phillips #00 head 3.175mm screw located directly to the right of the silver plate.
ある他の人がこのガイドを完成しました。
