メインコンテンツにスキップ
Asus ZenFone 5 Lite Vibration Motor Replacement
必要な工具と部品
  1. 注意: 手順 1-6 は、作業進行中としてマークされている ガイド から引用されています。
    Asus ZenFone 5 Lite Vibration Motor Replacement, Charging Port: 手順 1、 2の画像 1 Asus ZenFone 5 Lite Vibration Motor Replacement, Charging Port: 手順 1、 2の画像 2
    • Use a thin plastic tool to peel the back cover of the phone off. Once the plastic tool has begun to pry the back off, slide the plastic tool around the edges of the phone to separate the adhesive holding the back on. Once all edges of the phone are disconnected, lift the back cover off.
    • Be careful to keep the cover and the rest of the phone close together so as not to break the connecting band between the touch sensor on the cover and the motherboard of the phone.
  2. Asus ZenFone 5 Lite Vibration Motor Replacement: 手順 2、 2の画像 1 Asus ZenFone 5 Lite Vibration Motor Replacement: 手順 2、 2の画像 2
    • Remove the seven Phillips #0 screws located on the bottom of the phone.
    • One of the seven screws is covered by a white sticker with the letters “CS” on it. This screw can be removed with the sticker still attached. Simply pierce through the sticker with the screwdriver and unscrew as normal.
  3. Asus ZenFone 5 Lite Vibration Motor Replacement: 手順 3、 2の画像 1 Asus ZenFone 5 Lite Vibration Motor Replacement: 手順 3、 2の画像 2
    • Use the nylon spudger to pry off the lower cover. Use the opening tool to help lift it off.
  4. Asus ZenFone 5 Lite Vibration Motor Replacement: 手順 4、 1の画像 1
    • Use a prying tool to gently pry off the connection that was previously hidden by the black cover.
    • Use one finger to hold down the charging port circuit board while prying off the connection to ensure it does not break.
  5. Asus ZenFone 5 Lite Vibration Motor Replacement: 手順 5、 2の画像 1 Asus ZenFone 5 Lite Vibration Motor Replacement: 手順 5、 2の画像 2
    • Locate the gold-tipped black wire attached to the charging port circuit board.
    • Insert the plastic prying tool underneath the silver clasp and pry it off.
  6. Asus ZenFone 5 Lite Vibration Motor Replacement: 手順 6、 2の画像 1 Asus ZenFone 5 Lite Vibration Motor Replacement: 手順 6、 2の画像 2
    • Insert a plastic prying tool on the left side of the charging port. Gently lift up the charging port and then remove using your hand.
  7. Asus ZenFone 5 Lite Vibration Motor Replacement, Vibration Motor: 手順 7、 1の画像 1
    • The vibration motor is the circular metallic piece located at the bottom right of the phone.
    • Using the plastic spudger, pry up the vibration motor starting at the top right. The motor is held down with adhesive, so some force may be required.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Philipp Tolxdorf
メンバー登録日: 02/25/19
267 ポイント
2のガイドは作成済み
チーム
Purdue University Northwest, Team S4-G6, Hingst Spring 2019 Purdue University Northwest, Team S4-G6, Hingst Spring 2019人のメンバー
PNW-HINGST-S19S4G6
5 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 10
今までの合計 734
