はじめに
The front camera is located on the top of the screen facing outward. The camera can have internal damage that will require a replacement, such as a cable being disconnected. The front facing camera can have several issues, including a black screen or just blurry photos.
必要な工具と部品
Peel off the silver tape that is to the right of the audio jack about halfway, so it is off of the silver plate.
Use the tweezers to disconnect the press fit connector underneath the tape, right above the silver plate.
Gently lift up until the camera and the connector is removed.
ある他の人がこのガイドを完成しました。
