メインコンテンツにスキップ
Asus ZenFone 3 Zoom Screen Replacement
必要な工具と部品
  1. Asus ZenFone 3 Zoom Screen Replacement, Screen Replacement: 手順 1、 2の画像 1 Asus ZenFone 3 Zoom Screen Replacement, Screen Replacement: 手順 1、 2の画像 2
    • Use sim card attachment for the screwdriver found in the IFIXIT box to remove the sim card tray from the phone.
  2. Asus ZenFone 3 Zoom Screen Replacement: 手順 2、 1の画像 1
    • Remove the 3.5 mm screws on both sides of the charging port, at the bottom of the phone, using the T2 screwdriver.
  3. Asus ZenFone 3 Zoom Screen Replacement: 手順 3、 2の画像 1 Asus ZenFone 3 Zoom Screen Replacement: 手順 3、 2の画像 2
    • Use the opening tool to separate the screen and the plastic body of the phone.
  4. Asus ZenFone 3 Zoom Screen Replacement: 手順 4、 1の画像 1
    • Utilize the PH #00 attachment to remove the two 3.3 mm screws in the bracket to the top left of the battery.
  5. Asus ZenFone 3 Zoom Screen Replacement: 手順 5、 1の画像 1
    • After removing the bracket and screws, pull up on the battery from the bottom of the unit and set aside.
  6. Asus ZenFone 3 Zoom Screen Replacement: 手順 6、 2の画像 1 Asus ZenFone 3 Zoom Screen Replacement: 手順 6、 2の画像 2
    • Remove all three screws near the top of the phone with the PH #00.
    • The top right and left screws are 3.25 mm.
    • The middle screw is 2.65 mm.
  7. Asus ZenFone 3 Zoom Screen Replacement: 手順 7、 1の画像 1
    • De-solder the single black speaker wire attached on the left side of the phone.
  8. Asus ZenFone 3 Zoom Screen Replacement: 手順 8、 2の画像 1 Asus ZenFone 3 Zoom Screen Replacement: 手順 8、 2の画像 2
    • Use the flat-edge side of iFixIt plastic spudger to detach both of the ribbon cables off of the motherboard at their connection point.
  9. Asus ZenFone 3 Zoom Screen Replacement: 手順 9、 2の画像 1 Asus ZenFone 3 Zoom Screen Replacement: 手順 9、 2の画像 2
    • Use the tweezers to lift up on the edges of the motherboard located above where the battery was, then remove the motherboard.
  10. Asus ZenFone 3 Zoom Screen Replacement: 手順 10、 2の画像 1 Asus ZenFone 3 Zoom Screen Replacement: 手順 10、 2の画像 2
    • Remove the speaker cover at the bottom of the casing by taking out all five 3.25 mm screws with the PH #00.
  11. Asus ZenFone 3 Zoom Screen Replacement: 手順 11、 1の画像 1
    • Gently pry off the ribbon cable from speaker housing with the flat-edge side of the iFixit plastic spudger.
  12. Asus ZenFone 3 Zoom Screen Replacement: 手順 12、 1の画像 1
    • Remove the speaker once exposed.
  13. Asus ZenFone 3 Zoom Screen Replacement: 手順 13、 1の画像 1
    • Use iOpener to soften the adhesive keeping the screen on the device.
  14. Asus ZenFone 3 Zoom Screen Replacement: 手順 14、 1の画像 1
    • Pry off the screen beginning at the right-hand side toward the bottom of the phone with the plastic flat-edge spudger.
  15. Asus ZenFone 3 Zoom Screen Replacement: 手順 15、 1の画像 1
    • Progress around the perimeter of the phone with the pry tool till the screen is off.
  16. Asus ZenFone 3 Zoom Screen Replacement: 手順 16、 2の画像 1 Asus ZenFone 3 Zoom Screen Replacement: 手順 16、 2の画像 2
    • Remove the screen by pulling the attached ribbon cable out through the exposed opening.
  17. Asus ZenFone 3 Zoom Screen Replacement: 手順 17、 1の画像 1
    • The finished product will be a screen with nothing attached to the body of the phone.
ゴール
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Luke Theiss
メンバー登録日: 07/10/19
271 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S2-G3, Harley Summer 2019 IUPUI, Team S2-G3, Harley Summer 2019人のメンバー
IUPUI-HARLEY-SU19S2G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 29
今までの合計 2,426
