メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. Asus ZenFone 3 Max Repairability Assessment, Asus ZenFone 3 Max Repairability Assessment: 手順 1、 3の画像 1 Asus ZenFone 3 Max Repairability Assessment, Asus ZenFone 3 Max Repairability Assessment: 手順 1、 3の画像 2 Asus ZenFone 3 Max Repairability Assessment, Asus ZenFone 3 Max Repairability Assessment: 手順 1、 3の画像 3
    • Reference front/back
    • No glass on the back is nice.
    d ont forget to remove the sim card tray befor
    Martin - 返信
  2. Asus ZenFone 3 Max Repairability Assessment: 手順 2、 3の画像 1 Asus ZenFone 3 Max Repairability Assessment: 手順 2、 3の画像 2 Asus ZenFone 3 Max Repairability Assessment: 手順 2、 3の画像 3
    • Super stiff clips around the perimeter of the "bathtub" rear case, hardcore prying required to remove the rear case. Seam is super thin and tough to get tools into.
    • Fingerprint sensor cable connects rear case to rest of the phone, makes a little trap when you're opening it up.
    • Not enough slack to lay the rear case on its side to continue working on the phone, sensor cable must be disconnected.
    • Fingerprint sensor itself is pretty easy to push out of the rear case. Has a standard press-on connector.
    • Side button covers can also be removed at this point.
  3. Asus ZenFone 3 Max Repairability Assessment: 手順 3、 2の画像 1 Asus ZenFone 3 Max Repairability Assessment: 手順 3、 2の画像 2
    • Battery pull-tab adhesive strips are nice.
    • But they broke pretty easily. The right, almost immediately, the left, slightly later
    • It was relatively easy to remove the battery, the left adhesive strip was pretty much freed from the batter, the right had to be wrestled off. Could be removed by hand, no tools needed.
    Asus zenfone 3 Max screen display
    Vablilsetti Ramsai - 返信
  4. Asus ZenFone 3 Max Repairability Assessment: 手順 4、 2の画像 1 Asus ZenFone 3 Max Repairability Assessment: 手順 4、 2の画像 2
    • Phillips #00 screws secure the top antenna frame and lower speaker assembly.
    • One screw is hidden under a tamper-evident seal.
  5. Asus ZenFone 3 Max Repairability Assessment: 手順 5、 1の画像 1
    • Daughterboard is thin and adhered fairly solidly to the display assembly, making removal a bit dangerous.
    • Vibrator and charging port are soldered to the daughterboard. High-use charging port will someday fail, board is relatively bare, but still pricier than the port alone.
    • Button switch cable is adhered, but not too bad.
    • Antenna cable immediately accessible.
    • Motherboard is also adhered and tough to remove, being in a well in the display assembly.
  6. Asus ZenFone 3 Max Repairability Assessment: 手順 6、 1の画像 1
    • The cameras can only be freed after motherboard removal.
    • The headphone jack is soldered to the board. As is the card slot.
  7. Asus ZenFone 3 Max Repairability Assessment: 手順 7、 1の画像 1
    • The only remaining removable component is the earpiece speaker.
    • Display assemblies like this (fused display and midframe assembly) make for pricy replacement parts. This component is also the last out, while it's the most in danger of failing from simple falls etc.
    • While it is possible to replace just the LCD and digitiser It may be more trouble than it's worth
    • To remove the old screen from the assembly heat (freezing might work better, but I have not tried) the screen and press on the screen through this hole, then It's just a matter of lots of heat and scraping.
    • removing the old LCD/digitiser from the assembly with almost certainly destroy it.
    • Removing the LCD/digitiser without scattering broken glass everywhere may not be possible
    • it takes a LOT of heat to remove the LCD/digitiser, you may melt the screen for the earpiece speaker if you are not careful (or even if you are)
  8. Asus ZenFone 3 Max Repairability Assessment: 手順 8、 2の画像 1 Asus ZenFone 3 Max Repairability Assessment: 手順 8、 2の画像 2
    • The Asus ZenFone 3 Max earns a 6 out of 10 on our repairability scale (10 is the easiest to repair):
    • Battery is easily accessible and removable.
    • Parts could be more modular, especially mechanical/high wear components.
    • The opening procedure is extremely tough, clips are stiff and likely to be broken, and the SIM slot bends easily.
    • The single unit display assembly is annoying to reach, and will be a costly part.
ゴール
31 の人々がこのガイドを完成させました。
Sam Goldheart
メンバー登録日: 2012年10月18日
452,369 ポイント
548のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
145 メンバー
15,562のガイドは作成済み
3 件のコメント
Hi! my phone was broken as per service center say’s it was the board that’s broken , please help
Jesslie Tapang - 返信
My screen is broken. I cant seem to find anywhere that can fix it
Yvonne Cross - 返信
Need to buy LCD/Digitiser assy urgently,
eBay o/s 20-35 days.
Aus supplier??
John Barber - 返信
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 82
今までの合計 25,231
