メインコンテンツにスキップ
Asus ZenFone 2 Motherboard Replacement
必要な工具と部品
  1. Asus ZenFone 2 Motherboard Replacement, Removing the Back Cover: 手順 1、 2の画像 1 Asus ZenFone 2 Motherboard Replacement, Removing the Back Cover: 手順 1、 2の画像 2
    • Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
  2. Asus ZenFone 2 Motherboard Replacement, Remove the Inner Cover Screws: 手順 2、 1の画像 1
    • Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
    • The black screws are 2.8 mm in length.
    • The silver screw is 5.5 mm in length.
    • The black screw next to the camera and the flash is covered by a sticker. This screw can be easily removed as if there were no sticker on top of it. The point of the screwdriver should be able to pierce through the sticker easily.
  3. Asus ZenFone 2 Motherboard Replacement, Remove the Inner Cover: 手順 3、 2の画像 1 Asus ZenFone 2 Motherboard Replacement, Remove the Inner Cover: 手順 3、 2の画像 2
    • Use a plastic opening tool to remove the inner phone backing.
    • The parts of the inner backing held down by two strips of double sided tape can be easily loosened by inserting the plastic opening tool underneath it and gently lifting it up.
  4. Asus ZenFone 2 Motherboard Replacement, Remove the Speaker: 手順 4、 1の画像 1
    • Note the position of the speaker unit so you can replace it in the correct place during reassembly.
    • Take the speaker out of the back of the phone. It should come out easily as soon as the inner back is removed because nothing is holding it down in place anymore.
  5. Asus ZenFone 2 Motherboard Replacement, Remove the Antenna: 手順 5、 2の画像 1 Asus ZenFone 2 Motherboard Replacement, Remove the Antenna: 手順 5、 2の画像 2
    • Use a plastic opening tool to gently pry up both ends of the antenna.
    • Carefully remove the antenna wire from the plastic keepers along the side. Note their position for reassembly.
    • The antenna connections can be easily bent out of shape. Be sure to lift from underneath the cable as shown.
  6. Asus ZenFone 2 Motherboard Replacement, Unlock Circuit Board Ribbon Cable: 手順 6、 2の画像 1 Asus ZenFone 2 Motherboard Replacement, Unlock Circuit Board Ribbon Cable: 手順 6、 2の画像 2
    • Using the plastic opening tool, unlock the ribbon cable attaching the battery to the circuit board by prying up the yellow tab.
  7. Asus ZenFone 2 Motherboard Replacement, Remove Vibration Motor: 手順 7、 1の画像 1
    • Using a plastic opening tool, gently pry the vibration motor from its mount.
  8. Asus ZenFone 2 Motherboard Replacement, Remove Circuit Board: 手順 8、 1の画像 1
    • Gently remove the circuit board from the phone by gently pulling it away from the bottom of the phone.
  9. Asus ZenFone 2 Motherboard Replacement, Disconnect Ribbon Cables: 手順 9、 2の画像 1 Asus ZenFone 2 Motherboard Replacement, Disconnect Ribbon Cables: 手順 9、 2の画像 2
    • Using the plastic opening tool, disconnect the ribbon cables from their connectors by gently prying them up.
  10. Asus ZenFone 2 Motherboard Replacement, Remove the Battery: 手順 10、 1の画像 1
    • Carefully remove the battery pack from the phone using your hand. The battery is glued in placed by a strip of adhesive on the top side so some force may be necessary.
    • There are fragile tabs on the left and right side of the battery, be careful not to break them off.
  11. Asus ZenFone 2 Motherboard Replacement, Lift up the Copper Heat Strip: 手順 11、 3の画像 1 Asus ZenFone 2 Motherboard Replacement, Lift up the Copper Heat Strip: 手順 11、 3の画像 2 Asus ZenFone 2 Motherboard Replacement, Lift up the Copper Heat Strip: 手順 11、 3の画像 3
    • Using a plastic opening tool, lift the copper sheet heat strip from the body of the phone by sticking the tool into one of the upper corner of the copper sheet and slowly sliding it along the edges.
    • Be careful not to rip the copper sheet.
  12. Asus ZenFone 2 Motherboard Replacement, Detach the Motherboard Ribbon Cable: 手順 12、 2の画像 1 Asus ZenFone 2 Motherboard Replacement, Detach the Motherboard Ribbon Cable: 手順 12、 2の画像 2
    • Using a plastic opening tool, unplug the ribbon cable indicated in the picture.
  13. Asus ZenFone 2 Motherboard Replacement, Detach the Screen Connector Ribbon Cable: 手順 13、 2の画像 1 Asus ZenFone 2 Motherboard Replacement, Detach the Screen Connector Ribbon Cable: 手順 13、 2の画像 2
    • Using a plastic opening tool, disconnect the display cable from the side of the motherboard by carefully sticking the tool underneath the display cable and gently pulling outward.
  14. Asus ZenFone 2 Motherboard Replacement, Remove the Motherboard from the Retaining Clips: 手順 14、 3の画像 1 Asus ZenFone 2 Motherboard Replacement, Remove the Motherboard from the Retaining Clips: 手順 14、 3の画像 2 Asus ZenFone 2 Motherboard Replacement, Remove the Motherboard from the Retaining Clips: 手順 14、 3の画像 3
    • There are four black plastic retainers, two on each side, that keep the motherboard fix in place. To get the motherboard out, stick a plastic opening tool under one top corner of the motherboard and carefully lift upward using a small amount of force to pop this side of the motherboard out of the plastic retainers.
    • Be careful not to break the black plastic retainers as these are needed to put the motherboard back in place.
  15. Asus ZenFone 2 Motherboard Replacement, Finish Removing the Motherboard: 手順 15、 1の画像 1
    • Once one side of the motherboard is out of the black plastic retainers, remove the whole motherboard from the phone.
    • The motherboard should come out easily once one side of it is freed from the black plastic retainers.
終わりに
Put in a new motherboard and reassemble your device by following these instructions in reverse order.
41 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Eduardo Nodarse
メンバー登録日: 02/10/16
4,797 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 2-5, Sullivan Spring 2016 USF Tampa, Team 2-5, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S2G5
4 メンバー
16のガイドは作成済み
20 件のコメント
Hi!I
After replacing the complete appliance front but the unit turns on but nothing appears on the screen, what may have happened?
horacildo - 返信
Check if the screen ribbon cable is firmly attached to the motherboard. If it is you may have a faulty motherboard replaced or a faulty screen
Nathan The Neko -
Thanks this helped a lot, Download Asus full firmware here: https://www.droidtechie.com/official-ful...
Sam Peter - 返信
Is there any place where I can order just the audio jack?
Sergio Lapunov - 返信
Is there a reliable source to buy a motherboard you can suggest? I need to replace the audio jack. Thank you for the neat guide.
sriram010689 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 41
今までの合計 52,261
