メインコンテンツにスキップ
Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement
必要な工具と部品
  1. Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement, Motherboard: 手順 1、 1の画像 1
    • Remove all ten T5 screws on the back cover near the edges.
    • Remove two Phillips #1 screws located under the rubber feet near the screen.
  2. Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement: 手順 2、 3の画像 1 Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement: 手順 2、 3の画像 2 Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement: 手順 2、 3の画像 3
    • Use a metal spudger to gently separate the keyboard from the computer case.
    • Do not completely remove the keyboard as there are two ribbon cables that connect the keyboard to the motherboard.
    • Lift the keyboard slightly, and use a plastic spudger to release the two ZIF connections to free each ribbon cable.
    • Remove the keyboard.
  3. Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement: 手順 3、 1の画像 1
    • Use the Phillips #1 screwdriver to remove all 5 mm screws.
  4. Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement: 手順 4、 1の画像 1
    • Use a plastic opening tool or nylon spudger to lift the monitor connections off of the main board.
  5. Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement: 手順 5、 2の画像 1 Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement: 手順 5、 2の画像 2
    • Clip off the battery from the main board.
    • Use of a metal spudger can cause damage to the device or harm to the user, especially near the battery! Use an ESD safe tool for this step instead.
  6. Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement: 手順 6、 2の画像 1 Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement: 手順 6、 2の画像 2
    • Remove the black foam above the screw on the I/O board.
    • Remove the 5 mm #1 Phillips head screw.
  7. Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement: 手順 7、 2の画像 1 Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement: 手順 7、 2の画像 2
    • Pull the I/O board away from the chip to detach it.
    • Remove the I/O board and main board.
  8. Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement, Wi-Fi Wireless Card: 手順 8、 3の画像 1 Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement, Wi-Fi Wireless Card: 手順 8、 3の画像 2 Asus ZenBook Flip UX360C Wi-Fi Wireless Card Replacement, Wi-Fi Wireless Card: 手順 8、 3の画像 3
    • Use the metal spudger to remove the chip connections.
    • Gently pull the chip up and to the left to remove it from the device.
終わりに
作成者
2人の作成者と共同で作成されました。
Daniel Updyke
メンバー登録日: 02/25/19
73 ポイント
1ガイドが承認済み
チーム
Purdue University Northwest, Team S4-G4, Hingst Spring 2019 Purdue University Northwest, Team S4-G4, Hingst Spring 2019人のメンバー
PNW-HINGST-S19S4G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 1,280
