ツール
パーツ
この手順は未翻訳です。 翻訳を手伝う。
Use the plastic opening tool to pry off the black plastic strip at the bottom of the screen by wiggling the tool between the strip and the screen.
Run the opening tool slowly along the base of the screen, peeling the black strip back, until the opposite end of the screen is reached.
この手順は未翻訳です。 翻訳を手伝う。
Place the computer on its back, facing up.
Wedge the plastic opening tool in between the screen and the bezel of the aluminum computer casing.
Move the tool along the entire edge of the screen with an up-and-down prying motion to loosen the screen from the casing. Do not lift the entire screen away from the computer yet.
ある他の人がこのガイドを完成しました。
