メインコンテンツにスキップ
Asus X55C HDD (Hard Disk Drive) Replacement
必要な工具と部品
ビデオの概要
  1. Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): 手順 1、 3の画像 1 Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): 手順 1、 3の画像 2 Asus X55C HDD (Hard Disk Drive) Replacement, HDD (Hard Disk Drive): 手順 1、 3の画像 3
    • Switch off the Laptop and remove the Battery.
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
  2. Asus X55C HDD (Hard Disk Drive) Replacement: 手順 2、 3の画像 1 Asus X55C HDD (Hard Disk Drive) Replacement: 手順 2、 3の画像 2 Asus X55C HDD (Hard Disk Drive) Replacement: 手順 2、 3の画像 3
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  3. Asus X55C HDD (Hard Disk Drive) Replacement: 手順 3、 1の画像 1
    • Remove the two Philips screws and separate the HDD from the caddy case.
    • You can install 2.5" SATA HDD, 5400rpm / 7200rpm, 320GB / 500GB / 750GB /1TB.
    • After changing / upgrading the HDD you must install an operating system or clone & copy the information from the old HDD to the new one.
    • Did you do it successfully.
    • Please SUBSCRIBE to my channel ツ
    Okay so I was needing to upgrade hdd on this exact model and it worked great for the first part but putting the cover on didn’t work any ideas?
    Eject tech tips - 返信
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
191,278 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,528のガイドは作成済み
コメント 1 件
Were do you get the OS already installed on the drive. I have a Asus 550 with a 500 G and win 8.1. Looking to up grade to win 10 YES i have the GEO FORCE graphic card. Will I loose the use of the GEO FORCE. card. It has a i7 chip. And 6 g of line one cache would like to take to like 16 G… I would like to use the solid state hard drive. I understand it weathers bounces. Small slams and bangs better than the disc type. But I may not beable to afford this high a upgrade. Recommendations chrisdeiotte7@gmail.com
Chris Deiotte - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 28
今までの合計 11,405
