はじめに
We will show you how to open the laptop and change / upgrade the HDD (hard disk drive).
Please SUBSCRIBE to my channel ツ
ビデオの概要
  1. Switch off the Laptop and remove the Battery. Unscrew the two Philips screws and remove the HDD / RAM Cover. Unscrew the two Philips screws and remove the HDD / RAM Cover.
    • Switch off the Laptop and remove the Battery.
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Remove three screws securing the hard drive caddy (hard drive assembly). Slide the hard drive assembly to the left to disconnect it from the motherboard. Slide the hard drive assembly to the left to disconnect it from the motherboard.
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  4. Remove the two Philips screws and separate the HDD from the caddy case.
    • Remove the two Philips screws and separate the HDD from the caddy case.
    • You can install 2.5" SATA HDD, 5400rpm / 7200rpm, 320GB / 500GB / 750GB /1TB.
    • After changing / upgrading the HDD you must install an operating system or clone & copy the information from the old HDD to the new one.
    • Did you do it successfully.
    • Please SUBSCRIBE to my channel ツ
まとめ
3 の人々がこのガイドを完成させました。
ZFix
メンバー登録日: 2013年12月09日
162,554 ポイント
304のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
280 メンバー
784のガイドは作成済み
統計データを表示:
過去 24時間: 4
過去 7 日: 19
過去 30 日: 99
今までの合計 6,682
