メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
How to disassemble the laptop and replace the CMOS / BIOS Battery.
__________________ Video manual: __________________
ビデオの概要
  1. Switch off the laptop and remove the battery.
    • Switch off the laptop and remove the battery.
  2. The Keyboard is held by 5x locking clips. Pick up a little the one side of the Keyboard and start opening the clips one by one. Disconnect the Keyboard flex cable from the mother board and remove the KB.
    • The Keyboard is held by 5x locking clips.
    • Pick up a little the one side of the Keyboard and start opening the clips one by one.
    • Disconnect the Keyboard flex cable from the mother board and remove the KB.
    • Please SUBSCRIBE to my channel ツ
  3. Remove the screw. Pull out the SATA DVD Drive.
    • Remove the screw.
    • Pull out the SATA DVD Drive.
  4. Remove 3x Philips screws. Disconnect the two small flex cables:
    • Remove 3x Philips screws.
    • Disconnect the two small flex cables:
    • Power On button flex cable
    • Touch pad flex cable
  5. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  6. Unscrew the two Philips screws and remove the HDD / RAM Cover. Remove three screws securing the hard drive caddy (hard drive assembly). Slide the hard drive assembly to the left to disconnect it from the motherboard.
    • Unscrew the two Philips screws and remove the HDD / RAM Cover.
    • Remove three screws securing the hard drive caddy (hard drive assembly).
    • Slide the hard drive assembly to the left to disconnect it from the motherboard.
  7. Disconnect the two coaxial antenna cables from the Wi-Fi card. Remove any Memory or Dummy card.
    • Disconnect the two coaxial antenna cables from the Wi-Fi card.
    • Remove any Memory or Dummy card.
  8. The bottom cover is held by 10x Phillips screws. Remove them. With a plastic tool separate the Upper cover and remove it. With a plastic tool separate the Upper cover and remove it.
    • The bottom cover is held by 10x Phillips screws. Remove them.
    • With a plastic tool separate the Upper cover and remove it.
  9. Disconnect: The Microphone cable The LCD Display flex cable
    • Disconnect:
    • The Microphone cable
    • The LCD Display flex cable
    • Remove 3x Pillips screws.
    • Lift the board first from the right edge.
    • There is another one cable, from the DC connector, connected to the underside of main board. We should spun the the board to disconnect the DC connector cable.
  10. ASUS X55C iCore with 4GB no board RAM motherboard, model: 60-N0OMB1100 Please SUBSCRIBE to my channel  ツ
  11. Use a sharp tool to remove the Battery. CR2032 -  button cell lithium battery rated at 3.0 volts. Did you do it successfully?
終わりに
7 の人々がこのガイドを完成させました。
ZFix
メンバー登録日: 2013年12月09日
172,102 ポイント
307のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
294 メンバー
937のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 75
今までの合計 12,923
