メインコンテンツにスキップ
Asus X555LA-SI305041 Battery Replacement
必要な工具と部品
  1. Asus X555LA-SI305041 Battery Replacement, Keyboard Assembly: 手順 1、 1の画像 1
    • Remove the following Phillips #0 screws from the lower case:
    • Six 9 mm screws
    • Four 11 mm screws
  2. Asus X555LA-SI305041 Battery Replacement: 手順 2、 1の画像 1
    • Use the plastic opening tool to separate the top cover from the laptop.
    • Start by prying on the front of the laptop.
    • Continue prying around the cover and end just under the screen to release the front cover.
    • Do not fully remove the top cover, it is attached by two ribbon cables that will be disconnected in the following steps.
  3. Asus X555LA-SI305041 Battery Replacement: 手順 3、 1の画像 1
    • To release the ZIF latch, flip up the small white tab.
    • The connector may have a white base with a small grey rotating latch.
    • Pull the white ribbon cable out of the socket to disconnect it.
    • Very little force should be required to pull out the cable.
  4. Asus X555LA-SI305041 Battery Replacement: 手順 4、 1の画像 1
    • To release the ZIF latch on the keyboard cable, flip the grey rotating tab up.
    • Gently pull the black and blue ribbon cable out of its connector.
  5. Asus X555LA-SI305041 Battery Replacement: 手順 5、 1の画像 1
    • You can now fully remove the keyboard and front panel to gain access to the inside of the laptop.
  6. Asus X555LA-SI305041 Battery Replacement, Battery: 手順 6、 1の画像 1
    • Remove the three 5mm Phillips #0 screws securing the battery.
  7. Asus X555LA-SI305041 Battery Replacement: 手順 7、 1の画像 1
    • Gently remove battery from casing. The battery should remove easily.
    • Replace with new battery.
終わりに
37 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Garrett Doll
メンバー登録日: 09/28/15
1,072 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team 1-1, Matresse Fall 2015 Eastern Washington University, Team 1-1, Matresse Fall 2015人のメンバー
EWU-MATRESSE-F15S1G1
4 メンバー
13のガイドは作成済み
10 件のコメント
Great and easy explanation! THANK YOU!
susanbedd - 返信
If the Asus f555la battery is buying at Chennai,if any availability?? Response to ashokkumara24@gmail.com.
Tommy Kumar - 返信
Hmmm. A couple of the screw lengths look a bit suspect. At step 1, the six 90mm screws? That’s nearly four inches long!! And at step 6, three 50mm screws? I haven’t started this yet, but my guess is that the respective lengths should be 9mm and 5mm respectively. But apart from that, the article reads very well; just what I was looking for. Thanks!
Albert - 返信
how many hours will this battery last? I bought a new laptop Asus x455L and the fully charged battery only lasts 3 hours. I’ve already adjusted my screen brightness to 40% and turned off WIFI & Bluetooth
Shaley - 返信
MY PROBLEM ……THE BATTERY HAD GROWN….INFLATED ITSELF…AND IN SO DOING, ELEVATED THE KEYBOARD AT THE  LEFT HAND SIDE, AND PREVENTED THE LID/SCREEN FROM CLOSING EVENLY.THE  BATTERY ALTHOUGH BLOATED,WAS STILL OPERATING  OK & WAS NOT LEAKING…..                               James King - 23/02 2018
James King - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 37
過去 30 日: 153
今までの合計 82,136
