はじめに
The Asus X551CA spacer keeps the laptop light weight and stable, but also provides the owner with the option to instal an optical drive.
必要な工具と部品
Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
Two 4.3 mm screws in the back corners
One 17.5 mm screw at the left edge near the optical drive
Three 4.3 mm screws in the front edge
Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
4 の人々がこのガイドを完成させました。
