はじめに
The front display bezel holds the LCD screen to the base of the laptop.
パーツ
パーツは必要ありません。
Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
Two 4.3 mm screws in the back corners
One 17.5 mm screw at the left edge near the optical drive
Three 4.3 mm screws in the front edge
Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
Locate both of the hinges that connect the monitor to the bottom plate cover.
5 の人々がこのガイドを完成させました。
