メインコンテンツにスキップ
Asus X551CA Fan Replacement
必要な工具と部品
  1. Asus X551CA Fan Replacement, Keyboard Plate Cover: 手順 1、 1の画像 1
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
  2. Asus X551CA Fan Replacement: 手順 2、 1の画像 1
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
  3. Asus X551CA Fan Replacement: 手順 3、 1の画像 1
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
  4. Asus X551CA Fan Replacement: 手順 4、 3の画像 1 Asus X551CA Fan Replacement: 手順 4、 3の画像 2 Asus X551CA Fan Replacement: 手順 4、 3の画像 3
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
  5. Asus X551CA Fan Replacement: 手順 5、 1の画像 1
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
  6. Asus X551CA Fan Replacement, Hard Drive: 手順 6、 1の画像 1
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
  7. Asus X551CA Fan Replacement: 手順 7、 1の画像 1
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
  8. Asus X551CA Fan Replacement: 手順 8、 1の画像 1
    • Once it is free, remove the hard drive from its internal cavity.
  9. Asus X551CA Fan Replacement, Spacer: 手順 9、 1の画像 1
    • Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
  10. Asus X551CA Fan Replacement: 手順 10、 1の画像 1
    • Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
  11. Asus X551CA Fan Replacement, WiFi Card: 手順 11、 1の画像 1
    • Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
  12. Asus X551CA Fan Replacement: 手順 12、 1の画像 1
    • Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
  13. Asus X551CA Fan Replacement: 手順 13、 1の画像 1
    • Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
  14. Asus X551CA Fan Replacement, Battery: 手順 14、 1の画像 1
    • Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
  15. Asus X551CA Fan Replacement, Motherboard: 手順 15、 1の画像 1
    • With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
  16. Asus X551CA Fan Replacement: 手順 16、 2の画像 1 Asus X551CA Fan Replacement: 手順 16、 2の画像 2
    • Now, locate the two wires connected to the motherboard.
  17. Asus X551CA Fan Replacement: 手順 17、 2の画像 1 Asus X551CA Fan Replacement: 手順 17、 2の画像 2
    • Remove the wires by easily pulling them parallel to the motherboard's surface.
    • The wires are very fragile. Be sure to pull carefully so that they do not break!
  18. Asus X551CA Fan Replacement: 手順 18、 2の画像 1 Asus X551CA Fan Replacement: 手順 18、 2の画像 2
    • Remove the LCD display connection by gently pulling on the attached wire.
    • Gently lift any tape that may be holding the connection.
  19. Asus X551CA Fan Replacement: 手順 19、 1の画像 1
    • Remove the motherboard from the case by gently lifting it upward.
  20. Asus X551CA Fan Replacement, Fan: 手順 20、 1の画像 1
    • Once the mother board is removed, locate the fan.
  21. Asus X551CA Fan Replacement: 手順 21、 1の画像 1
    • Using the Phillips #0 screwdriver, remove the 5.5 mm Phillips #0 screw holding the fan in place.
  22. Asus X551CA Fan Replacement: 手順 22、 1の画像 1
    • Lift the fan out of the laptop.
終わりに
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Josh
メンバー登録日: 04/10/14
2,958 ポイント
12のガイドは作成済み
チーム
Cal Poly, Team 7-22, Regan Spring 2014 Cal Poly, Team 7-22, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S7G22
5 メンバー
15のガイドは作成済み
コメント 1 件
Upgrade the memory while you have the motherboard out. 8GB PC3L-12800 SODIMM
iceman - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 5,685
