はじめに
This guide will instruct you on how to replace the optical drive in your Asus X5511M-RCLN03 laptop.
必要な工具と部品
ある他の人がこのガイドを完成しました。
3 件のコメント
Peer Review:
Title: This should be changed, as this portion of the device is not a DVD player. It is a CD ROM drive.
Step 1: This step is unclear and seems unnecessary. It should be removed, or reworded to be more specific: "Position the laptop with the back cover facing upward."
-Step 2: This step should specify what screwdriver to use. Using markup in the image would also help the user with locating the screws.
Step 3: This step is also unclear and seems unnecessary. It should be removed, or reworded: "Re-position the laptop with the back cover facing downward."
-Step 4: This step is missing articles (i.e. pry up “the” keyboard using a spudger). Also, it should specific what spudger to use (plastic). The user should know not to use a metal spudger on their device.
Step 5: This step is missing an article (remove “the” screw).
Step 6: This step is unclear, and should refer to the “CD ROM drive”, not a DVD player. It should be reworded to be more clear. Example: “Slide out the CD ROM drive to remove it.”
Edit the title and link to the guide so that they say CD-ROM drive instead of DVD player.
