メインコンテンツにスキップ
Asus X5511M-RCLN03 Optical Drive Replacement
必要な工具と部品
  1. Asus X5511M-RCLN03 Optical Drive Replacement, Optical Drive: 手順 1、 1の画像 1
    • Position the laptop with the back cover facing upward.
  2. Asus X5511M-RCLN03 Optical Drive Replacement: 手順 2、 1の画像 1
    • Remove all nine 4 mm screws from the back cover.
  3. Asus X5511M-RCLN03 Optical Drive Replacement: 手順 3、 1の画像 1
    • Open the laptop with the keyboard facing upward."
  4. Asus X5511M-RCLN03 Optical Drive Replacement: 手順 4、 1の画像 1
    • Pry up the keyboard using a plastic spudger.
  5. Asus X5511M-RCLN03 Optical Drive Replacement: 手順 5、 1の画像 1
    • Remove the four, 4 mm screws using a Phillips #00 screwdriver.
  6. Asus X5511M-RCLN03 Optical Drive Replacement: 手順 6、 1の画像 1
    • Slide out the CD-ROM.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Andrew Hemphill
メンバー登録日: 01/12/17
179 ポイント
1ガイドが承認済み
チーム
Oakland University, Team 2-5, Ruskiewicz Winter 2017 Oakland University, Team 2-5, Ruskiewicz Winter 2017人のメンバー
OAK-RUSKIEWICZ-W17S2G5
3 メンバー
2のガイドは作成済み
3 件のコメント
Peer Review:
Title: This should be changed, as this portion of the device is not a DVD player. It is a CD ROM drive.
Step 1: This step is unclear and seems unnecessary. It should be removed, or reworded to be more specific: "Position the laptop with the back cover facing upward."
-Step 2: This step should specify what screwdriver to use. Using markup in the image would also help the user with locating the screws.
Step 3: This step is also unclear and seems unnecessary. It should be removed, or reworded: "Re-position the laptop with the back cover facing downward."
Courtney Clark - 返信
-Step 4: This step is missing articles (i.e. pry up “the” keyboard using a spudger). Also, it should specific what spudger to use (plastic). The user should know not to use a metal spudger on their device.
Step 5: This step is missing an article (remove “the” screw).
Step 6: This step is unclear, and should refer to the “CD ROM drive”, not a DVD player. It should be reworded to be more clear. Example: “Slide out the CD ROM drive to remove it.”
Courtney Clark - 返信
Edit the title and link to the guide so that they say CD-ROM drive instead of DVD player.
Courtney Clark - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 690
