メインコンテンツにスキップ
Asus X5511M-RCLN03 Battery Replacement
必要な工具と部品
  1. Asus X5511M-RCLN03 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Position the laptop with the back cover facing upward.
  2. Asus X5511M-RCLN03 Battery Replacement: 手順 2、 1の画像 1
    • Remove all 4 mm screws using a #00 Philip's screwdriver.
  3. Asus X5511M-RCLN03 Battery Replacement: 手順 3、 1の画像 1
    • Open the laptop with the keyboard facing upward.
  4. Asus X5511M-RCLN03 Battery Replacement: 手順 4、 1の画像 1
    • Carefully pry up the keyboard cover with your fingers or with a plastic spudger.
  5. Asus X5511M-RCLN03 Battery Replacement: 手順 5、 2の画像 1 Asus X5511M-RCLN03 Battery Replacement: 手順 5、 2の画像 2
    • Remove electrical ribbons by gently lifting up the tab that is holding them down, then pulling them gently.
  6. Asus X5511M-RCLN03 Battery Replacement: 手順 6、 1の画像 1
    • Set the keyboard plate aside. Gently lift up battery to remove it.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ryann Easterbrook
メンバー登録日: 01/12/17
154 ポイント
1ガイドが承認済み
チーム
Oakland University, Team 2-5, Ruskiewicz Winter 2017 Oakland University, Team 2-5, Ruskiewicz Winter 2017人のメンバー
OAK-RUSKIEWICZ-W17S2G5
3 メンバー
2のガイドは作成済み
3 件のコメント
Peer review:
Step 1: This step is unclear and seems unnecessary. It should be removed or reworded to be more specific: "Position the laptop with the back cover facing upward."
Step 3: This step is also unclear and seems unnecessary. It should be removed or reworded: "Re-position the laptop with the back cover facing downward."
Step 5: This step is grammatically confusing and should be reworded. Example: "Lift up the tab covering the electrical ribbons. Pull the ribbons gently to remove them."
Courtney Clark - 返信
Steps 5 and 6 are missing photos so the instruction is not clear.
Courtney Clark - 返信
This was a easy and strait forward repair it took longer to find the tools than to do the repair. The hardest part for me was plugging the flex cables back in as I have a tremor in my hands. the repair took about 10 minutes.
DANIEL HATHAWAY - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 1,587
