メインコンテンツにスキップ
Asus X550ZA-SA100603E RAM Replacement
必要な工具と部品
  1. Asus X550ZA-SA100603E RAM Replacement, RAM: 手順 1、 1の画像 1
    • Place the computer screen side down and remove the 14 mm and 4 mm screws on the bottom of the computer. Locate all 10 screws and completely unscrew them.
    • Seven 14 mm screws
    • Three 4 mm screws
    • Make sure to keep the screws for reassembly.
  2. Asus X550ZA-SA100603E RAM Replacement: 手順 2、 1の画像 1
    • Carefully turn the computer onto its bottom, and gently pull the bottom apart from the top.
  3. Asus X550ZA-SA100603E RAM Replacement: 手順 3、 1の画像 1
    • Take a flathead driver, and gently pry open a gap between the keyboard and the lower piece. This should uncover the laptop's internals.
    • The flathead driver has the potential to damage the device. Be careful when handling it.
    • Do not be alarmed if you hear a click as you pry open. These sounds are the clips detaching from the casing.
  4. Asus X550ZA-SA100603E RAM Replacement: 手順 4、 2の画像 1 Asus X550ZA-SA100603E RAM Replacement: 手順 4、 2の画像 2
    • The motherboard is the big board on the left-hand side of the internals. Remove all 15 bordering screws that hold the motherboard in place.
  5. Asus X550ZA-SA100603E RAM Replacement: 手順 5、 2の画像 1 Asus X550ZA-SA100603E RAM Replacement: 手順 5、 2の画像 2
    • Carefully flip the motherboard over to expose the bottom of the board. You should find the RAM slots located on the right-hand side of the bottom of the motherboard.
  6. Asus X550ZA-SA100603E RAM Replacement: 手順 6、 1の画像 1
    • Take two fingers and pull the securing slots outward. The RAM stick should easily pop out. Take the old stick out, and carefully put the new one in the slot.
    • You will hear a clicking noise once it is pushed in.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Paul Flynn
メンバー登録日: 01/14/19
16 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S5-G5, Wilson Spring 2019 IUPUI, Team S5-G5, Wilson Spring 2019人のメンバー
IUPUI-WILSON-S19S5G5
3 メンバー
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 417
