メインコンテンツにスキップ
Asus X550ZA-SA100603E Battery Replacement
必要な工具と部品
  1. Asus X550ZA-SA100603E Battery Replacement, Keyboard: 手順 1、 1の画像 1
    • Using the Phillips #0 screwdriver, remove the seven 14 mm screws on the bottom of the laptop.
    • Then use the Phillips #0 to remove the three 4 mm screws on the bottom of the laptop.
  2. Asus X550ZA-SA100603E Battery Replacement: 手順 2、 3の画像 1 Asus X550ZA-SA100603E Battery Replacement: 手順 2、 3の画像 2 Asus X550ZA-SA100603E Battery Replacement: 手順 2、 3の画像 3
    • Insert a plastic opening tool between the keyboard and base of the laptop to pry the keyboard away from the base. Do this around the entire perimeter of the laptop.
    • This disconnects the face of the keyboard. Gently lift the keyboard up to expose the motherboard.
    • There are still ribbon cables connecting the keyboard face to the motherboard. Do not pull the keyboard away roughly.
  3. Asus X550ZA-SA100603E Battery Replacement: 手順 3、 3の画像 1 Asus X550ZA-SA100603E Battery Replacement: 手順 3、 3の画像 2 Asus X550ZA-SA100603E Battery Replacement: 手順 3、 3の画像 3
    この手順で使用する道具:
    購入する
    • Gently lift the keyboard to access the three ribbon cables connected to the motherboard
    • Using precision tweezers, flip up the white and black retaining flaps on the ZIF connectors that hold the two smaller ribbon cables in place.
    • Gently pull the ribbon cables from their sockets on the motherboard.
  4. Asus X550ZA-SA100603E Battery Replacement: 手順 4、 3の画像 1 Asus X550ZA-SA100603E Battery Replacement: 手順 4、 3の画像 2 Asus X550ZA-SA100603E Battery Replacement: 手順 4、 3の画像 3
    • Push the two white clamps on the large ZIF connector towards the screen.
    • Gently remove the track pad ribbon cable from its connector.
  5. Asus X550ZA-SA100603E Battery Replacement: 手順 5、 1の画像 1
    • Remove the keyboard.
  6. Asus X550ZA-SA100603E Battery Replacement, Battery: 手順 6、 2の画像 1 Asus X550ZA-SA100603E Battery Replacement, Battery: 手順 6、 2の画像 2
    • Disconnect the multi-wire battery plug from the motherboard.
  7. Asus X550ZA-SA100603E Battery Replacement: 手順 7、 3の画像 1 Asus X550ZA-SA100603E Battery Replacement: 手順 7、 3の画像 2 Asus X550ZA-SA100603E Battery Replacement: 手順 7、 3の画像 3
    • Pull the two tabs holding the battery in place and lift the battery up. It should remove easily.
終わりに
6 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Tim Linton
メンバー登録日: 04/06/17
796 ポイント
5のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 18
今までの合計 6,149
