はじめに
The screen or display of your laptop may break because of physical damage. If so, you can replace it using this guide.
必要な工具と部品
Using the tweezers, remove the 2 black plastic adhesive covers from the bottom corners of the screen frame.
Flip the laptop around and lay the screen flat on your work space with the laptop hinge away from you and the keyboard assembly standing vertical.
もう少しです!
終わりに
