メインコンテンツにスキップ
Asus X502CA-BCL0901D Battery Replacement
必要な工具と部品
  1. Asus X502CA-BCL0901D Battery Replacement, Keyboard: 手順 1、 1の画像 1
    • Flip the laptop over so that it is upside down.
  2. Asus X502CA-BCL0901D Battery Replacement: 手順 2、 1の画像 1
    • Remove the 11 screws from the bottom of the laptop with the Phillips #00 screwdriver.
    • All the screws are 20 mm in diameter. The 4 screws that are furthest from the hinge are 50 mm long, the other 7 are 90 mm long.
  3. Asus X502CA-BCL0901D Battery Replacement: 手順 3、 2の画像 1 Asus X502CA-BCL0901D Battery Replacement: 手順 3、 2の画像 2
    • Use the Plastic Opening Tool to pry the keyboard assembly away from the rest of the laptop.
    • Take care not to lift the keyboard assembly to far away from the laptop as there are short cables that need to be disconnected first.
  4. Asus X502CA-BCL0901D Battery Replacement: 手順 4、 1の画像 1
    • While lifting the keyboard assembly, use the tweezers to gently remove the keyboard cable and the touch pad cable by pulling the wires away from the laptop base. Both cables must be gently but firmly pulled towards you for safe removal.
  5. Asus X502CA-BCL0901D Battery Replacement: 手順 5、 2の画像 1 Asus X502CA-BCL0901D Battery Replacement: 手順 5、 2の画像 2
    • Lift the keyboard assembly away from the remainder of the laptop.
  6. Asus X502CA-BCL0901D Battery Replacement, Battery: 手順 6、 1の画像 1
    • Unplug the battery from the laptop with the tweezers.
    • If the battery is not unplugged, the motherboard may shock you.
  7. Asus X502CA-BCL0901D Battery Replacement: 手順 7、 2の画像 1 Asus X502CA-BCL0901D Battery Replacement: 手順 7、 2の画像 2
    • Using the Phillips #00 screwdriver, unscrew the 6 screws holding the battery in place.
    • Each screw is 50 mm in length and 15 mm in diameter.
  8. Asus X502CA-BCL0901D Battery Replacement: 手順 8、 1の画像 1
    • Lift the battery out of the laptop.
終わりに
作成者
2人の作成者と共同で作成されました。
Gregory Browne
メンバー登録日: 10/19/17
501 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S3-G5, Bailey Fall 2017 UMass Dartmouth, Team S3-G5, Bailey Fall 2017人のメンバー
UMASSD-BAILEY-F17S3G5
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 5
今までの合計 280
