メインコンテンツにスキップ
Asus X502C-RB01 Motherboard Replacement
必要な工具と部品
  1. Asus X502C-RB01 Motherboard Replacement, Keyboard Panel: 手順 1、 1の画像 1
    • Turn off the laptop and flip it face down.
    • Using a Phillips #0 screwdriver, remove the seven 9mm screws circled in red.
    • With the same screwdriver, remove the four 5mm screws circled in orange.
  2. Asus X502C-RB01 Motherboard Replacement: 手順 2、 1の画像 1
    • Flip the laptop face up and open the lid.
    • Use the plastic opening tool to pry around the entire edge of the keyboard panel to loosen the panel from the base.
    • Be careful not to lift the panel just yet, as it is still connected to the motherboard.
  3. Asus X502C-RB01 Motherboard Replacement: 手順 3、 2の画像 1 Asus X502C-RB01 Motherboard Replacement: 手順 3、 2の画像 2
    • Partially lift the panel up, revealing the two cables connected to the motherboard.
  4. Asus X502C-RB01 Motherboard Replacement: 手順 4、 2の画像 1 Asus X502C-RB01 Motherboard Replacement: 手順 4、 2の画像 2
    • Disconnect the first ZIF cable by lifting the tab using the spuger tool or your fingernail and gently pull the cable out.
    • Disconnect the second ZIF cable by lifting the tab using your fingernail and gently pull the cable out. This one is more difficult to reach with the spudger.
  5. Asus X502C-RB01 Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the keyboard panel completely and set it aside. The internal components of the laptop are now exposed.
  6. Asus X502C-RB01 Motherboard Replacement, Hard Drive: 手順 6、 1の画像 1
    • Locate the hard drive in the area highlighted in red.
    • This demonstration model does not have a mounting bracket around the hard drive.
  7. Asus X502C-RB01 Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the four 5mm screws from the hard drive mounting bracket using the Phillips #0 screwdriver.
  8. Asus X502C-RB01 Motherboard Replacement: 手順 8、 1の画像 1
    • Slide the hard drive in the direction away from the connector and lift it up to remove it.
  9. Asus X502C-RB01 Motherboard Replacement, Motherboard: 手順 9、 1の画像 1
    • Unplug the battery from the laptop by lifting the connector up with the flat end of the spudger.
    • Unplug the two ZIF cables by lifting the tab using the spudger tool or your fingernail then pulling the cable out gently.
  10. Asus X502C-RB01 Motherboard Replacement: 手順 10、 1の画像 1
    • Unplug the bundled cable by pulling it away from the connector with a bit of force.
    • Unplug the display cable connector by lifting the tape and pulling it away from the connector.
    • Unplug the two antenna cables connected to the network interface card by prying it off with the flat end of the spudger.
  11. Asus X502C-RB01 Motherboard Replacement: 手順 11、 2の画像 1 Asus X502C-RB01 Motherboard Replacement: 手順 11、 2の画像 2
    • Remove the four 5.5mm screws using the Phillips #0 screwdriver.
  12. Asus X502C-RB01 Motherboard Replacement: 手順 12、 1の画像 1
    • Gently lift the motherboard out of the casing.
終わりに
作成者
4人の作成者と共同で作成されました。
Jaspal Chauhan
メンバー登録日: 01/19/17
491 ポイント
4のガイドは作成済み
チーム
UC Davis, Team 1-5, Rodger Winter 2017 UC Davis, Team 1-5, Rodger Winter 2017人のメンバー
UCD-RODGER-W17S1G5
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 955
