メインコンテンツにスキップ
Asus X501A-RH31 Fan Replacement
必要な工具と部品
  1. Asus X501A-RH31 Fan Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 Fan Replacement: 手順 2、 1の画像 1
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 Fan Replacement: 手順 3、 2の画像 1 Asus X501A-RH31 Fan Replacement: 手順 3、 2の画像 2
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 Fan Replacement, Keyboard: 手順 4、 2の画像 1 Asus X501A-RH31 Fan Replacement, Keyboard: 手順 4、 2の画像 2
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 Fan Replacement: 手順 5、 1の画像 1
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 Fan Replacement: 手順 6、 2の画像 1 Asus X501A-RH31 Fan Replacement: 手順 6、 2の画像 2
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 Fan Replacement: 手順 7、 1の画像 1
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 Fan Replacement: 手順 8、 1の画像 1
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
  9. Asus X501A-RH31 Fan Replacement, Fan: 手順 9、 1の画像 1
    • Unscrew the three screws using the Phillips #00 screwdriver.
    • The three screws are 5 mm in length, 4.2 mm in diameter.
  10. Asus X501A-RH31 Fan Replacement: 手順 10、 1の画像 1
    • Unscrew the three screws on the left hand side of the big motherboard.
    • This will loosen the motherboard, which will allow for better access to the cables in the next step.
    • The three screws are 5 mm in length, 4.2 mm in diameter and Phillips head screws.
  11. Asus X501A-RH31 Fan Replacement: 手順 11、 3の画像 1 Asus X501A-RH31 Fan Replacement: 手順 11、 3の画像 2 Asus X501A-RH31 Fan Replacement: 手順 11、 3の画像 3
    • Remove the connector cable attached to the bottom of the motherboard.
    • Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Christopher
メンバー登録日: 10/19/17
359 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 UMass Dartmouth, Team S3-G3, Bailey Fall 2017人のメンバー
UMASSD-BAILEY-F17S3G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 9
今までの合計 522
