メインコンテンツにスキップ
Asus X401A Wireless Card Replacement
必要な工具と部品
  1. Asus X401A Wireless Card Replacement, Wireless Card: 手順 1、 1の画像 1
    • Use a Phillips head #1 screwdriver to remove the eight 3mm screws.
    • Use a Phillips head #1 screwdriver to remove the two 4mm screws.
  2. Asus X401A Wireless Card Replacement: 手順 2、 2の画像 1 Asus X401A Wireless Card Replacement: 手順 2、 2の画像 2
    • After removing the screws from the underside, flip the laptop over and, using a plastic opening tool, remove the keyboard panel
    • To efficiently remove the keyboard panel, use the opening tool in a prying motion
    • When reattaching the keyboard panel, press firmly until snaps are heard, indicating the panel has been reattached.
  3. Asus X401A Wireless Card Replacement: 手順 3、 3の画像 1 Asus X401A Wireless Card Replacement: 手順 3、 3の画像 2 Asus X401A Wireless Card Replacement: 手順 3、 3の画像 3
    • Disconnect these cables by unlocking the ZIF connectors with a spudger.
  4. Asus X401A Wireless Card Replacement: 手順 4、 2の画像 1 Asus X401A Wireless Card Replacement: 手順 4、 2の画像 2
    • Using a Phillips Head 1 Screwdriver, remove all screws securing the motherboard to the frame of the laptop
  5. Asus X401A Wireless Card Replacement: 手順 5、 2の画像 1 Asus X401A Wireless Card Replacement: 手順 5、 2の画像 2
    • Use a spudger to lift up on the ZIF tab and remove the USB/charing port ribbon cable.
    • Use a spudger to release the speaker's bundled cable from the connector.
    • After disconnecting the USB/Charging port board completely, remove and set aside, as it would otherwise obstruct future steps.
  6. Asus X401A Wireless Card Replacement: 手順 6、 2の画像 1 Asus X401A Wireless Card Replacement: 手順 6、 2の画像 2
    • Peel back the tape securing the cable for the laptop's screen. It is not recommended you disconnect the cable at this time, as you risk damaging the cable.
  7. Asus X401A Wireless Card Replacement: 手順 7、 3の画像 1 Asus X401A Wireless Card Replacement: 手順 7、 3の画像 2 Asus X401A Wireless Card Replacement: 手順 7、 3の画像 3
    • Using the plastic spudger tool, lift up the fan from the frame of the laptop using a prying motion, which will also lift the motherboard
    • As you remove the motherboard, pull it towards the left to allow the ports on the opposite side to slide out easily from their slots.
    • As you lift the motherboard, disconnect the video cable mentioned in the previous step.
  8. Asus X401A Wireless Card Replacement: 手順 8、 3の画像 1 Asus X401A Wireless Card Replacement: 手順 8、 3の画像 2 Asus X401A Wireless Card Replacement: 手順 8、 3の画像 3
    • Identify the wireless card on the underside of the motherboard and remove the 2 screws holding it in place
    • As you remove the second screw, the wireless card will spring up on its own
  9. Asus X401A Wireless Card Replacement: 手順 9、 2の画像 1 Asus X401A Wireless Card Replacement: 手順 9、 2の画像 2
    • Remove the wireless card along its angle, and insert your replacement card at the same angle.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Connor Santee
メンバー登録日: 02/07/17
149 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-4, Wilder Spring 2017 Ohio State, Team 1-4, Wilder Spring 2017人のメンバー
OSU-WILDER-S17S1G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 851
