メインコンテンツにスキップ
Asus X401A Internal Fan Replacement
必要な工具と部品
  1. Asus X401A Internal Fan Replacement, Internal Fan: 手順 1、 1の画像 1
    • Flip over the laptop and remove the battery for ease of replacement.
  2. Asus X401A Internal Fan Replacement: 手順 2、 3の画像 1 Asus X401A Internal Fan Replacement: 手順 2、 3の画像 2 Asus X401A Internal Fan Replacement: 手順 2、 3の画像 3
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Remove the screws located underneath the laptop by using a Phillips #00 screwdriver. This will assist you when disconnecting the keyboard cover from the rest of the laptop.
    • Remove the two 4mm screws.
    • Place the screws on a magnetic mat to not lose them.
  3. Asus X401A Internal Fan Replacement: 手順 3、 2の画像 1 Asus X401A Internal Fan Replacement: 手順 3、 2の画像 2
    • Flip the laptop back over and begin prying the keyboard cover from the rest of the laptop by using a plastic spudger.
    • The keyboard is still attached to the motherboard via two ribbon cables. Do not pull the keyboard away from the laptop.
  4. Asus X401A Internal Fan Replacement: 手順 4、 3の画像 1 Asus X401A Internal Fan Replacement: 手順 4、 3の画像 2 Asus X401A Internal Fan Replacement: 手順 4、 3の画像 3
    • Use a spudger to lift the ZIF tabs.
    • Remove both the black and white ribbon cables in order to completely detach the cover from the rest of the device.
  5. Asus X401A Internal Fan Replacement: 手順 5、 3の画像 1 Asus X401A Internal Fan Replacement: 手順 5、 3の画像 2 Asus X401A Internal Fan Replacement: 手順 5、 3の画像 3
    • Remove all screws that connect the motherboard to the bottom of the laptop.
    • The motherboard holds the internal fan in place
    • Before attempting to remove the motherboard, be sure to disconnect both sets of wires as pictured.
  6. Asus X401A Internal Fan Replacement: 手順 6、 2の画像 1 Asus X401A Internal Fan Replacement: 手順 6、 2の画像 2
    • Once all screws are removed and both sets of wires are detached, use a spudger to carefully pry up the motherboard along with the attached internal fan.
    • Set the rest of the laptop aside and direct your attention to only the motherboard.
  7. Asus X401A Internal Fan Replacement: 手順 7、 3の画像 1 Asus X401A Internal Fan Replacement: 手順 7、 3の画像 2 Asus X401A Internal Fan Replacement: 手順 7、 3の画像 3
    • Flip the motherboard over and you will notice four screws (circled in yellow) that are connecting the fan's bracket to the motherboard. Using your screwdriver, remove the four screws and place them off to the side.
  8. Asus X401A Internal Fan Replacement: 手順 8、 2の画像 1 Asus X401A Internal Fan Replacement: 手順 8、 2の画像 2
    • One final group of wiring will also be connecting the internal fan to the motherboard. Careful disconnect it as shown.
    • With the internal fan completely disconnected from the motherboard, you should be able to freely remove it.
    • Replace the faulty internal fan with a new one and repeat the previous steps for reassembly.
終わりに
作成者
2人の作成者と共同で作成されました。
Skylar Alexander
メンバー登録日: 02/07/17
137 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-4, Wilder Spring 2017 Ohio State, Team 1-4, Wilder Spring 2017人のメンバー
OSU-WILDER-S17S1G4
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 805
