はじめに
This guide provides step-by-step instructions on the replacement of the motherboard of ASUS X200MA. This guide can be used to upgrade or replace an obsolete, malfunctioning, or a damaged motherboard. Use caution when removing and installing the motherboard as it is connected to the hard drive.
必要な工具と部品
Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
2 の人々がこのガイドを完成させました。
