メインコンテンツにスキップ
Asus X200MA Motherboard Replacement
必要な工具と部品
  1. Asus X200MA Motherboard Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Motherboard Replacement: 手順 2、 1の画像 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Motherboard Replacement: 手順 3、 1の画像 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Motherboard Replacement, Battery: 手順 4、 1の画像 1
  5. Asus X200MA Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Motherboard Replacement: 手順 6、 1の画像 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Motherboard Replacement: 手順 8、 1の画像 1
    • Slide the battery up and out.
  9. Asus X200MA Motherboard Replacement, Fan: 手順 9、 1の画像 1
    • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
  10. Asus X200MA Motherboard Replacement: 手順 10、 2の画像 1 Asus X200MA Motherboard Replacement: 手順 10、 2の画像 2
    • Unplug the set of wires located at bottom corner on fan.
  11. Asus X200MA Motherboard Replacement: 手順 11、 2の画像 1 Asus X200MA Motherboard Replacement: 手順 11、 2の画像 2
    • Lift up and out to completely the remove fan component.
  12. Asus X200MA Motherboard Replacement, Motherboard: 手順 12、 1の画像 1
    • Use Phillips #0 screwdriver to remove the eight 4.0 mm screws.
  13. Asus X200MA Motherboard Replacement: 手順 13、 2の画像 1 Asus X200MA Motherboard Replacement: 手順 13、 2の画像 2
    • Pull back the blue ribbon, freeing it from the latch.
  14. Asus X200MA Motherboard Replacement: 手順 14、 3の画像 1 Asus X200MA Motherboard Replacement: 手順 14、 3の画像 2 Asus X200MA Motherboard Replacement: 手順 14、 3の画像 3
    • Lift and pull the motherboard out from the hard drive and remove it from the base plate.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Alli Krininger
メンバー登録日: 11/11/19
391 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S2-G4, Stella Fall 2019 IUPUI, Team S2-G4, Stella Fall 2019人のメンバー
IUPUI-STELLA-F19S2G4
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 1,240
