メインコンテンツにスキップ
Asus X200MA Battery Replacement
必要な工具と部品
  1. Asus X200MA Battery Replacement, Back Panel: 手順 1、 1の画像 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Battery Replacement: 手順 2、 1の画像 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Battery Replacement: 手順 3、 1の画像 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Battery Replacement, Battery: 手順 4、 1の画像 1
  5. Asus X200MA Battery Replacement: 手順 5、 1の画像 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Battery Replacement: 手順 6、 1の画像 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Battery Replacement: 手順 7、 1の画像 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Battery Replacement: 手順 8、 1の画像 1
    • Slide the battery up and out.
終わりに
29 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Vanessa Garcia
メンバー登録日: 01/22/15
1,763 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 21-24, Maness Winter 2015 Cal Poly, Team 21-24, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S21G24
4 メンバー
8のガイドは作成済み
8 件のコメント
Thanks for the write up! Easy to follow, Great photos, and worked great!
nathaniel forward - 返信
Your step by step instructions were so easy to follow. Great job. Thanks! :)
Fernando H - 返信
I would like to buy a battery to it, Please suggest me the best portal site
jagadeeshkumar maddala - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 57
今までの合計 35,473
